berry79
Thread starter- Joined
- Jul 5, 2009
- 109
I'm preparing to remove the cap to repair floor and transom. While cutting the lower section of the transom cut out I noticed about a 1" layer of filler. This was not present while cutting the side. My question is should I be cutting below this fill at the wood and not the lamination line? Also, I will be redoing the transom with nida-bond, should I just form it up to replace the 1" filler gap? Do the pourable transom need to fiberglassed over the top? And, when I replace the cap what should I use to bond this area back? May be that peanut butter mixture? Sorry for all the question, newb just wanting to make sure I do it right the first time. Thanks
