Benny1963
- Joined
- Sep 17, 2006
- 1,476
hello all ihave a 175 evin crossflow , rebuilt powerhead new stats waterpump brp complete kits the stats are complete with poppetts stainless kits ,
i had motor finale tuned by omc guy in tank with correct test prop
he did the link and sink and checked total timeing i had set it by joes method it was 1 degree off got boat back runs great its broke in .
i ran it on muffs today because im fixing to fish. on the muffs the exhaust outlet holes were putting out water and the pee stream is strong
but my right side lookig at back of motor is a little hotter than the left
ran at idle for 10 minutes can easily touch heads but the right side seems
hotter than left over heat alarm is good and not sounding ive overheated one ,so i know a little abut the heat issues ,does that side normaly run a little hotter than the other ,i believe i have read some post
on the cross flow motors that one bank runs a little hotter than the other
d hadley emsmanger one you guys ezeke am i good or do i need to check into it shoot it with gun or what it has new deflectors in the heads in the proper places double checked before finale assembly , will be putting temp gauges on it and waterpressure gauge on it im working on my setup thanks
