Faztbullet
- Joined
- Mar 2, 2008
- 15,931
Without a t-stat 2 scenarios can happen...1) Motor can run too cold no matter the incoming water temp. The cylinders cannot expand in relationship to piston heat and the rings/piston skirt scuff as expansion rate is off due to over cooling . That the purpose of t-stat to hold water till block warms up. then its a restrictor at WOT. Number 2) The motor runs hot as water passes thru block to quickly and never removes heat from cylinders that is transferred from the rings , block will fill good to touch or I/R gun but hot internally. You can see this with a EGT probe and all this can happen no matter the oil ratio
