cylinder identifycation
Rollin E. Drew
I have a 1996 Evinrude 150 HP V6 outboard. There are great many numbers embossed on the cylinder heads, how do I determine the correct cylinder head number. My manual does not offer such information. Thank you.
walleyehed
Re: cylinder identifycation
Welcome!<br />the number of the head is cast in...raised numbers would be the head numbers...should be 6 digit numbers and each head will be only 1 number off..find those and list'em.
Rollin E. Drew
Originally posted by walleyehed:<br /> Welcome!<br />the number of the head is cast in...raised numbers would be the head numbers...should be 6 digit numbers and each head will be only 1 number off..find those and list'em.
Rollin E. Drew
Thank you for the information. My question was asked, albeit not clearly, to determine cylinder numbers not the part number for the head. Thus in order to determine the firing order of the cylinders, one must know the number the manufacturer has assigned to each of the six cylinders. Thank you
OBJ
Rollin.....looking at the back of the engine...the starboard side (right) is odd numbered...1-3-5, top to bottom.<br /><br />Port side is even...2-4-6...top to bottom.
DHPMARINE
And the cylinder closest to the flywheel is #1.<br />I think OBJ told me that quite while back.I just had never looked at it that way.<br /><br />DHP
OBJ
Twernt me DHP....least I don't think it was.....good way to look at it though....<br /><br />I read it the same way Ken until I saw Rollin's last post..... :)
Rollin E. Drew
Originally posted by OBJ:<br /> Rollin.....looking at the back of the engine...the starboard side (right) is odd numbered...1-3-5, top to bottom.<br /><br />Port side is even...2-4-6...top to bottom.
