A friend of mine has a Merc 3.0, alpha 1. Just found out #4 has 0 compression via a leak down test. Mech gave him a quote of $1600 to repair. Sounds way high to me. Any insight?
That price isn't bad, even if it's just a bad valve.
The troublshooting cost too ya know, then you have take apart clean, repair, reinstall, and test run, plus gaurentee your work. With no parts and charging only 75 per hour, that's only 21 hours to do that job in the boat. We also can't see what access you have to your engine. Half of it may be under the back of the boat. Any parts will take away from that 21 hours.
