Re: dad giving me a Bass Tracker with issues!
Compression test and spark test
Remove all spark plugs and ground all the plug wires to prevent any stray sparks from igniting fuel vapors when you crank the motor.
Test compression on each cyl.
Test spark on each plug wire using an adjustable gap spark tester set to 7/16 inch. If any fail this test the motor will not make good power.
Joe Reeves posted a DIY Spark Tester somewhere here on iBoats, sorry I never saved that link. Find it, you need a board, nails and wire, very simple and effective.
