Augoose
Thread starter- Joined
- Mar 21, 2010
- 1,245
My father called me today and knowing that I frequent the best boating forum on earth
asked me to post a question!
About 2 years ago he turned in his boat, a 2001 Stingray with the 4.3 merc and Bravo I, to be put up into dry storage and winterized. During the routine maintenance the boat yard told him that they had found fishing line wrapped up beneath the prop. They removed the line and then replaced the "bearing" and the "seal", but added that the fishing line was wound up there so heavily that it caused the outer casing of the lower gear unit to change shape. This change of shape allegedly now prevents the seal from sealing correctly and thereby allows some seepage of the gear unit oil, so much that over the course of one albeit short season enough gear unit oil leaked out that my father had to add about a quart to the reservoir in the engine compartment.
Not wanting to intentionally introduce additional fuels, oils and/or contaminates into the lake, he is looking for second opinion and solutions. He trusts the boat yard but they have made several simple and accidental mistakes in the past, so he just wants to be sure.
Has anyone heard of fishing line actually causing the outer casing of the lower gear unit to change shape or become damaged so that the seal won't seal?
Thanks!
Thanks!
