damn this engine of mine!
Niander
im having some bad luck with this evinrude 20 hp 1975<br /> it was making a rythmic banging in forward gear now then nothing but its stuck in reverce...wont do newtrel...its gearbox or something :confused: <br />any ideas... :confused:
JB
Re: damn this engine of mine!
It would help if you had added this to your previous post rather than starting at zero, Niander.<br /><br />Either your gearbox or your shift linkage is coming apart.<br /><br />Don't try to use the engine any more until you have fixed it. If you keep ignoring it and trying to use it you only make it worse.<br /><br />Good luck. :)
Niander
yep thx ive already decided to take it to a pro to fix...and i aint going to sea backwards! :eek: ...if it was stuck in forwards maybe :D <br />thx 4 reply
Niander
ok out of interest ill tell ya what it was...i took it apart the cluch dog[correct word]? is worn.. all other gears etc are perfect :) <br />anyone think ill be able to get the part from anywhere??1975 ervinrude twin 20 hp<br />im in scotland btw<br />anyways im gunna build up wit weld and reprofile[i can c this has been done before]<br />until i get a new part ...as a final if that dont work ill fix it perminantly in forward gear :D <br />if it still jumps out :rolleyes:
Duck Loads
I once had a '72 (?) johnson 25 that would pop out of forward gear. I turned the shifter dog around to wear on the other side and it got me anouther couple of years. Just a thought.<br /><br />Good luck,<br /><br />Duck L.
Niander
thx m8 but its already been turned round :rolleyes: <br />i think its done good service but the engine is good apart from this<br />but im good wit the welder&grinder ;) <br />anyone thx the part is available??
iRich
Hi Niander, If you haven't found one yet try these people: http://www.fairwindsmarina.com/ <br />They have alot of parts for older engines. They are in Md. but they will ship to you. Give them a call.<br />Rich
G DANE
Hi Niander<br /><br />Clutch dogs are available at almost any dealer, price around 50 $.
Niander
are they?<br />well anyways i fixed it ...very carefull use of welder and grinder on that high precision cluchdog...she dont jump out anymores :D <br />ill get a new part if it does it again...but i still have a problem with carb in that it needs choke to take full throtal :confused: <br />then she flys ... :cool:
SeaMasterZ@aol.com
you know those Scots ... thrrrrrrrrrifty they are!<br /><br />Me, I hate rowing<br /><br />or swimming to shore, big feet or not!<br /><br /> :p
