Re: Dash chronicles
Tinkerer,<br /><br />I painted a VW beetle steering wheel with epoxy paint years ago. I had it for a few years after that and it never scratched from rings, etc.<br /><br />Another option for the dash is a piece of polycarbonate plastic. About 1/8" can be cut nice with a saber saw, then sand the edges and they look like the edge of auto door glass. The neat part is that it can be painted from the back side. The paint doesn't get scratched because it's on the back, and it has a nice deep clear finish. Silver, gold, black and white spray paints look the best, I think. Silver or gold might look nice with your color boat.<br /><br />It holds up to water well. You can put a bead of silicone around the edge and let it squish out and harden. After it hardens, trace the edge with a razor blade and peel off the excess silicone. <br /><br />I have done this in a car and painted it black. Looked like a factory piece. Did it in white for a control panel and silver on a electric guitar. You might what to test silver first because it can get a grain pattern in it if put on too wet. Light coats make it even. Remember it's your FIRST coat that you will see.<br /><br />I really like the spoke part of that steering wheel. It's gonna look great with fresh paint. Did you think of using vinyl 'dye' spray paint? I might work better than epoxy if its really soft. You will have to remove all the primer and clean it down to the original finish for it to work. It is designed to soak into plastic, not primer. It is flexable and strong enough to hold up to use on seats. Search for "SEM vinyl dye" on Yahoo.<br /><br />Don't you just hate it when people cut holes in dash boards?<br /><br />Mark.
