ajgraz
Thread starter- Joined
- Mar 1, 2010
- 1,858
Couldn't decide whether this is "freshwater" or "saltwater", so I put it in this subforum instead.
Middle school daughter is doing her science fair project on the effects of exposure to temperature and to common chemicals found on a boat on the strength of fishing line. We have the data already, but I'm looking for your "predictions" anyway to see if the "common wisdom" jibes with the reality
Anyway, took lengths of 4 lb test Izorline copolymer monofilament, and exposed them to these treatments for two weeks:
Temperature:
1) 40?C (lab oven)
2) 4?C (fridge)
3) 0?C (freezer)
4) -79?C (nitrogen freezer)
Chemical:
5) Fresh water (tap water run through Brita filter)
6) Salt water (water from 5) with 3.5% sea salt added)
7) Soda (Coca Cola)
8) Gasoline (E10, 87 octane)
9) 2-cycle oil (Walmart Supertech)
10) Spray sunscreen (Rite-Aid SPF30)
11) Fish attractant ("Bait Butter" brand shrimp paste)
Then tension tested to failure on a TA/XT-2 Analyzer (sort of a small-scale Instron Materials Tester), 10 reps per treatment.
Here's what I will tell you:
Now your "predictions"...which treatments fell into which ranges?
Temperature:
1) 40?C (lab oven)
2) 4?C (fridge)
3) 0?C (freezer)
Chemical:
7) Soda (Coca Cola)
- Control (no treatment) measured 1420 +/- 110 grams.
- One showed no change at all versus the control
- Two showed "minor" reduction in strength vs. control in the -15% to -20% range
- Three showed "significant" reduction in the -20% to -25% range
- Two showed "major" reduction in the -25% to -30% range
- Three showed "devastating" reduction in the -30% to -40+% range
