Re: De-carb question.
Not to be confrontational either but I've used hair dryers to get stuck bolts loose on outboards and model engine parts. I've also used steam irons to do it. That was before I bought a heat gun. I don't heat the bolts either, I heat the surrounding aluminum. Sometimes I put an ice cube on the bolt head right after heating the area around it too. <br /><br />Torches are best used on steel to loosen bolts. Aluminum can go from hard to liquid in a milisecond when using torches. If you don't know how to use them it could ruin your day. It only has to happen one time to make you a believer...I'm a believer at the cost of an Evinrude 15hp lower unit that had a stuck drain plug.
