fat fanny
Thread starter- Joined
- Feb 9, 2006
- 1,935
Upon dewinterizing the old girl today after work in preperation for the holiday weekend drained the A/F out of the block and mani pulled plugs to turn over a few times so as not to foul the plugs w/ fogging oil and just the clatter of the starter like it wasn't strong enough to turn the engine over? H ave had the battery on the charge on and off all winter after refilling with new acid but never repeated charge voltage metered the battery voltage and it read 12.3 volts I would have thought that would have been enough but no so just to be sure pulled starter and had nap test it and it worked perfectly engages fin plenty of torque replaced it and nada @that point I squirted some oil into the cylinders and turned it over easily w/a 3/8 ratchet and 1/2 socket on the cam shaft pully. I did get the starter to crank the engine over @ one point but didn't want to fry the starter so my conclusions are leading me to battery replacement? Whattaya guys think and by the way all the electrical connetions and grounds are tight and cleaned.
