De-winterized! Thanks for all of your help Mods and Members
gt2003
I had the boat winterized last year due to not having a manual and not having enough time to do it on my own. I've done research and asked questions since then, obtained all the needed greases, a fluid evacuator, proper filters, spark plugs etc. I jumped in the boat yesterday morning, put the engine and manifold plugs back in, re-connected the coil wire, put the battery back in, put on the muffs and fired her up.........SUCCESS! I ran her on muffs for about 10 minutes until the engine temp was right at 150-160, shut her down and changed the oil with my mityvac evacuator. AWESOME. That thing works really well and made the job pretty easy. I replaced the oil filter also. I didn't want to replace the plugs with the engine warm so I then removed the prop (a first for me) and greased the spline. Once again, pretty easy! My son and I took a break then I jumped upside down and backwards in the engine compartment and got the plugs changed. I had gapped them all last week so that was already done (I had greased/lubed the steering also). Once that was done she fired up again immediately. So, we headed to the lake and ran a half a tank of gas through her just running around the lake and locating different marinas that we didn't take the time to find last year. The oil pressure stayed great and the temperature stayed right at 150-160 when running. I periodically checked the engine compartment to make sure all was well and it was! So, I wanted to take a minute to say thank you ALL for such a great forum where us "newbies" can get sound advice on caring for our crafts! Your help is much appreciated!
LippCJ7
Re: De-winterized! Thanks for all of your help Mods and Members
Oh now thats just wrong, we help you get your boat winterized then you come on here and rub it in that your now summerized before everyone else!! Very rude!
I am so jealous of you I think I'm about a month away yet Congratulations and have a safe year!!:D
gt2003
Thanks! I wasn't able to get the fuel/water seperator filter off but that's part of the project for today. Is there a trick to it or was it just overtightened?
LippCJ7
Its probably overtightened, work it back and forth until it comes off, it happens sometimes, people get a bit carried away
QC
Hey gt, glad things are off to a roaring start. I'm assuming this is an Alpha. I don't see any drive maintenance noted . . . and I am guilty of putting this off sometimes even though I have the tools, but my boat is 250 miles away, so I find ways to procrastinate. You really need to pull the drive and check your drive alignment once a year, and I don't see any drive maintenance in your list or posts. Also, don't forget the gimbal ring torque. That one is very easy and the only tool you need is a torque wrench. For the drive alignment you need an alignment tool . . . Do some more reading over in the I/O section. I have a .pdf on the Maint manual if you want one. PM me with your email addy and I'll send it.
