for those who have seen my other posts, I have recently finished reinforcing the stringers, foaming under the floor, replacing the floor of my 1975 Thundercraft. Today I was going to take it out and see if all was right in the world again. I tried to start it in my driveway just to make sure it would start, and I ran into a problem.
The boat hasn't been run in a month and a half. I took the battery (almost brand new) off and stored it in the garage while I was working on the boat. I also ran the engine with the gas line disconnected to make sure the gas wouldn't sit in the carbs for all of this time. Fast forward to today, I hooked everything up and tried to start it. It turned over almost immediately, then it died (forgot to have the idle up!!! DOH!!). I tried to start it again several times and it wouldn't turn over. The battery sounded nice and strong. I tried to start it one more time and all I got was a "click" from the solenoid, nothing else. Tried several more times and only got the "click." I checked the voltage on the battery, it is 12.5 volts when resting, and it drops to 10.2 volts when I try to start. Does this sound like the battery needs a charge (which is what I am doing right now) or could it be another issue? The positve and negative cables felt very warm after all of this, and I looked them over to find that the positive cable was frayed in some areas (exposed wire). I don't think this was the problem today, but I am going to buy new cords and replace them tomorrow. Anything else that you would look into?
Finally, assuming I get the battery thing worked out, do you have any tips on getting the engine to turn over? I have the choke turned on and the idle turned all the way up.
Thanks for the tips!!!
