RCSConstruction
- Joined
- Mar 23, 2007
- 549
Have the boat in for new cables and such and the mechanic just called and said I am not getting spark in number 6!! Claims the spark plug is all wet with gas.
At idle it will start to "load up" and you have to give it some RPM's to clear it out.
If I had a DEAD cylinder wouldn't the idle be terrible? My only complaint was a "dead" spot when launching really hard to get onto plane.
All the plugs show signs of being rich, so I am hoping it's just a fouled plug?
I have never seen a motor idle so good with a dead cylinder. Has the slightest miss every once in awhile but not the pop-pop-pop you would normally get with a dead hole.
Any advice? If I have been running on 7cyl's all along wouldn't my boat run like crap? I am pretty sure I would have noticed a dead hole..
Completely stressed now as I just put a new motor in last season and closed cooling system.
The carb is a marine 4bbl edelbrock. The motor is a 5.7l vortec.
The boat listed below.
