RCSConstruction
- Joined
- Mar 23, 2007
- 549
Re: Dead cylinder??
What are your thoughts on a stud girdle?
My recommendation is: if the rv cam is the wrong match for your engine/app, just buy one that is. A new flat based hyd cam and lifters will be around $150 vs $600 to convert to roller. (steel cam, roller lifters, push rods, spyder and retainers, timing gear/chain, cam retainer plate, special fuel pump rod or elec fuel pump, and possible distributer gear) For our boat engines, the main advantage of a roller is less cam wear. While that is true, I wonder if the reliability of the roller lifters are less than the flat based. I've seen a few posts on roller lifter problems.
