fishinmedic
- Joined
- Jan 19, 2010
- 11
I have an 86 E60 that the VRO system was removed by a mechanic before I got the boat, it has never run properly since, goes from dry to flooded way too often and easily. I have been reading up on the VRO system for awhile. In the secret file, part of the conversion outlined is something that screws into the existing fuel pump. That link is dead. What does that part do? And if I need one, what is it called? Also, for the life of me, I cannot find where the oil line from the old tank was plugged. I've traced the two lines from the pump and don't see a plug or open ended hose anywhere. Motor does run, no warning beeps, except on initial key on.
