dead short
razzor
302 engine in a 77 Invader
Runs great and starts great run for a while and shut off and will not start again, won't even take a jump. Let sit for 30 mins and she fires back up again, Iv searched for bare wires and checked all connections however I am new at the boat thing, Im I missing something simple? Gauge shows charging well at all times when Running.
Thanks Razzor
Reel Poor
Re: dead short
At the large harness connector at the engine check the terminals for corrosion and tightness. I f the connector is loose on losing connection it will cause this type of problem.
razzor
Re: dead short
I'll do that right now, thanks Captain, razzor
stevieray
Re: dead short
When you say it won't start again, does the starter crank at all? Do you get a real small click when you turn the key or absolutely nothing?
razzor
Re: dead short
Absolutly nothing, won't even start with a jump.
lrlima
Re: dead short
I agree with Reel Poor... I had a friend with the exact same symptoms. The main / large harness or plug was all crudded up. Cleaned it up and was good to go.
Reel Poor
Re: dead short
Also check the wire terminals and connections on the red circut breakers (engine mounted).
bruceb58
Re: dead short
Just for future reference. You have an "OPEN" not a dead short.
Mahoney
Re: dead short
This happened to me at one time too, and oddly enough it turned out to be the neutral switch in the throttle control. Apperantly there was some very old grease in there that picked up some dirt over the years, and after cleaning the whole mechanism up and reaplying some fresh lubricant, everything was fine.
What I surmissed was happening in my case was that after shutting down and placing in neutral it took a while for the dirty grease to release the switch to its "neutral" position.
Just something to check.
Haut Medoc
Re: dead short
Mahoney, I thought you fell off the face of the earth! d:)
Mahoney
Re: dead short
Haha, picked up some motorcyles over the winter, but after taking the old Cobalt out for Seafair I am suckered back into the boat. Its running great, but I am getting water intrusion into the upper because of worn seals on the main bearing. The nut is "welded" on there so I can't get it off to replace the seals.
I have a line on an excact match upper that I can get to and replace seals, so in the meantime I am just being careful and changing gear oil every outing!
