Dealer add hitch to new truck
poconojoe
what do you get by paying more for a 'factory' hitch?
Seems all you get are the receiver, wiring and an automatic locker differential. No mention of any extra trans cooler, oil cooler, larger alternator. So, I guess if the dealer adds the receiver, all I'm missing out on is the locking rear.
poconojoe
I've never had a locking diff on a truck. Only hot rods for the 1/4 mile. My Ford Ranger pulled my boat fine without one. What are the advantages? Traction on a wet ramp? 4x4 would help with that if there was a traction issue. No?
WIMUSKY
Locker diff? Highly doubt it....... Limited slip.......
poconojoe
I was surprised too. The trailering package requires an automatic locking differential. And if you order the automatic locking differential, that requires the trailering package!
poconojoe
I had a 69 Mustang with an automatic locker made by Powertrax. When you drove normal, it acted like a regular differential, but when you jumped on it the axles would lock together. It was nice, but it made a lot of clunking noises.
WIMUSKY
My truck does the same thing. I think it's a matter of terminology.....
poconojoe
So, it must be a standard practice these days. And you're probably right...just a matter of different terminology.
TyeeMan
Master Chief Petty Officer
The GM locking differential is different than a limited slip. The locking mechanism is operated by fly weights and will only lock up if the "loose" tire is spinning approx. 200 rpm or less. So lets say your on the wet ramp ready to pull out, you ease into the gas and one tire just starts to spin slowly. At that moment the fly weight assy. spins and locks the other axle which is noticeable by a light clunk and all of a sudden you have traction.
Conversely, if on the same wet ramp and you want to try and be cool and leave a whole bunch of tire smoke by smashing the throttle to the floor, the locking assy has some self preservation and will not allow the other tire to lock up. There's some cool clips on you tube about it.
But to other posters points on what is and is not included on GM (particularly) towing packages, it's flat out strange! We had an 01 Burb, every option in the house including tow package. No locking diff and 3:23 (or something like that) gears. 08 Burb, has the hitch, no tow package, no tranny cooler. Why they don't automatically put a tranny cooler on vehicle that size is beyond me.
poconojoe
Thanks for that very informative post!
redneck joe
That sounds like a tow package, which i get. The OP in the op states reciever so what is special about a 'dealer' hitch /reciver. Personally ive installed most of my recivers, bought from uhaul..
redneck joe
Honestly do not know sir. Ive always just bolted mine and the ones i bought with were just bolted. That said, my body shop guy would throw a couple welds on for a 20 spot after i bolted.
WIMUSKY
Bolted...
Edit: Actually, my factory installed one is bolted and welded... Ram.....
poconojoe
I just looked under my Ford Ranger and it is bolted on. So, after all of this discussion, I've decided to pull the trigger on the Colorado and let the dealer install the receiver. This particular Colorado has everything in it that we wanted (with the exception of the receiver of course). They are giving me $10,000 for my 2008 Ranger which I think is very good as a trade-in.
roscoe
You're getting about 5,000 for the Ranger, and a 5,000 discount off the sticker on the Colorado.
You'd get that 5k discount off the sticker even without a trade-in.
poconojoe
Thanks, it'll be aware of that when we sit down and talk numbers.
