decarb 2nd tank?
when doing the seafoam decarbing method what is the reason for using a second smaller tank and fuel line
would using the regular tank and line be just as effective if i just brought a gas can with a 50:1 regular mix to dump in when done smoking?
freddyray21
Re: decarb 2nd tank?
to get the right mixture of sea foam to gas. If you dump a can a seafoam in 6 gallons of gas you dilute it too much. If you tank only has a gallon it it then dump the sea foam in your tank
Silvertip
Don't think he's saying that he'd use six gallons. Just add the Seafoam to the desired amount of fuel. When done, then refill with six gallons. Yes -- your plan is sound. Just be sure the small amount of fuel you use is a 50:1 mix.
ya silver is right that's what i was trying to say
just wanted to make sure there wasn't some other reason for it i was missing
thanx guys
