ondarvr
- Joined
- Apr 6, 2005
- 11,527
Re: decarb loosen too much rubbish into cylinder chamber and cause loss of compressio
Most manufactures won't state a specific PSI or range because there can be such a huge difference in readings from one gauge to another, which results in someone freaking out just like in this case. You don't need a high dollar gauge, just don't buy a cheap junk one.
Take it out and run it, if it's not running correctly check it out further to see what the issue is, pull the heads and look at the cylinder walls and the head gasket.
I am only going by the specs of my motor, and I would say just because they are all even doesn't mean my motor is in good shape, yes it may start ok and run ok, but my specs for this motor read as 145 - 165psi, .
