Re: Decarbing Gas Additive
I dont think you are going to find someone here that is going so tell you to go ahead and do what you want to do and not worry about it, which is what I think you are hoping for. If I thought there was a problem with a lot of crud in the engine and I wanted to do something about it, I think I would go about it slowly. Id do the seafoam in the intake first, let it sit overnight, Start it on the muffs and smoke my neighbors out, then when it cleared up I would drain the oil while it was warm and install the seafoam and some cheap oil and start it up and run it for awhile to get the mixture moved around, do the intake again and wait till the next day and smoke them out again. After it cleared up and the engine was warm Id drain the oil and put more seafoam in and more cheap oil, run it untill warm and shut it down. Next day Id start it up till warm, drain the oil and fill it with whatever oil I was going to use. Id use Chevron 15W40 if it were me. Then I would take it out on the Lake or river and run the pejazins out of it and then bring it back and change the oil again. That should do it. You are right in being concerned about plugging things up, so do this at your our risk!
