Don S
- Joined
- Aug 31, 2004
- 62,321
Re: decided to do it myself...lower shift cable
You will need seals 29 & 31 for the carrier, and oring #4 for the cap.
If there was water in the bellows, they may have not noticed oil or the oil hadn't leaked yet and the yoke may have gotten rusty. That in itself will take out a front seal. Then the rust imbeds in the seal and grinds the groove in the sealing surface even deeper. Then each time you run it, when it warms up it pumps out more oil. I see it happen all the time. Most just ignore the yoke and seal.
Before I bought the boat ,end of fall,the gimbal bearing all bellows, impeller were changed less than 1 yr..Wouldn't you think tech would have noticed this?
