Deck coating / Turned complete restore
Status
Not open for further replies.
Woodonglass
Honorary Supreme Mariner
Re: Deck coating / Turned complete restore
If the outside of the tank is not badly corroded you can use Dawn Dish soap and boiling water to clean the inside. Fill it 1/2 full with boiling water and 1/2 cup of Dawn. Slosh it around for 10-15 minutes then let it set and repeat this every 15 minutes for a couple of hours. Dump it out then get a length of chain and put it in the tank. Then Slosh the chain around inside the tank for quite a while as well to loosen all the Carp that's inside. Pour in a couple more gallons of boiling water and Dawn and clean it up again. Then treat the inside with the POR-15 Gas Tank treatment and then Paint the outside with the Por-15 Paint. The Tank will be like new and last for Decades. That's my story and I'm stickin to it. IF the tank is heavily Pitted with corrosion...Replace it!!! IMHO below deck tanks should be Aluminum, Strapped in place with Nylon straps and NOT foamed in. That's just MY OPINION. I KNOW what others think and What the USCG and other research posted on this forum says. I've read it as well as SEEN what foamed in tanks look like when they have been removed and what the water has done to them. If an aluminum tank is left to BREATHE and NOT encapsulated in foam to SWEAT and stand in Water and you coat it aluminum with a protective coating like POR-15 then IMHO you will go a long way to avoid corrosion problems for the long term. Again Just an Old Dumb Okie's Opinion That's NEVER owned a Boat with a Below Deck Tank so What do I KNOW. Just PURE Speculation on my part based on Logic and Research. Worth everything you paid for it!!!!:D
ahmincha
Thanks jb and wood that sounds like a good plan. Will update after tank inspection
ahmincha
Starting to grind just want to make sure I am not going to far
ahmincha
This is my bilge area picture taken from stern forward it only drains from front upper deck I would like to do away with it as I am sealing up the front area is there any issues with doing this
ahmincha
This is a picture of where the wood around the fuel tank was. I have read that you must get to good glass The lighter glass is the residue of the glass used to attach the wood to the hull does all this need to come off or only if its loose
ahmincha
Woodonglass
Yup you gots lots of grinding left to do. Think of where any and all glass tabbings will be and that's where you need to have the hull ground down to fresh glass.
ahmincha
So all old tabbing must be removed I guess its time to grind
jc55
Looking good, you've been busy.
ahmincha
ahmincha
Those are pics of my gunwales I believe the deck was redone once before I am not sure how much to grind it seems like there is resin but no fiber it getting very wavy any suggestions
Woodonglass
When It's Clean and "Pinkish" color you're good to go!
ahmincha
Thanks Wood Hi jc nice to hear from you have you started your new project yet
ahmincha
I know I am being a little redundant but is this what I am looking for
Woodonglass
The Pink stuff yes, the Black stuff NO!!!
ahmincha
Thanks wood the black stuff is actually a 1x that is 2" away from gunwales that the decking sits on this boat has no stringers
ahmincha
Wood since I have your attention What do you think about me doing away with the front section of bilge area being as how I plan on sealing up front upper decks pros and cons thanks
ahmincha
Took a break from grinding built a cradle
Woodonglass
I'd like to see a sketch of what you propose for your New Bilge before I advise you on it.
ahmincha
area in black is existing bilge at stern that I want to keep area in green is where fuel tank goes the area in red goes to front of boat from the fuel tank to the bow I want to fill with foam
Status
