Deck coating / Turned complete restore
Status
Not open for further replies.
ahmincha
Re: Deck coating / Turned complete restore
Here is the new side deck support boards pre resin and csm the last picture is where my deck will be as opposed to the motor bolts
ahmincha
well csm on one side I am already ahead of original build they didn't put any thing on these barely had them tabbed in. I do not plan on doing the bottoms being as how I am setting them in pb make sense please correct me if I am wrong
ahmincha
Wood by not putting csm and only resin do you feel is a shortcut I am not looking to skimp just makes sense to me thanks
Woodonglass
Nope, perfectly acceptable. coating the bottom edge will seal it and the PB will cap it off. I see No way for water to penetrate the wood. You're good to go.
ahmincha
Ok I might wind up with a small 6hp tiller motor would it make sense to put it on this boat for safety if main motor goes out.And is 6hp enough to get you home on a 19' boat
Woodonglass
Depends on the conditions. Rough water and head winds...Might be a problem!!!:eek: I'd prolly look for a 10-15hp.
ahmincha
Ok if I put a kicker I will have to deal with the issue that these are hollow. Drill over sized holes and fill with pb or drill over sized holes and use spacers. Or any better ideas
Woodonglass
OR get some 16lb HIGH density foam from USC to fill those small areas. You can beat that stuff with a Sledge hammer and barely dent it.
ahmincha
What about resin and 1/4" chopped poured in no thickening
ahmincha
I will only have to do one. It is tapered hard to see in picture 3/4" to 2"
Woodonglass
Any way you could fabricate a wooden wedge to "Kinda" fit the area and then fill in the rest of the area with PB?? The issue is a thick portion of Resin gets HOT when it "Kicks Off" and that's not a good thing. I don't like to go over 3/4-1" thick with it.
ahmincha
Do not think there would be a way to get wood in there would it help or hurt if I were to do it in multiple pours
ahmincha
For curiosity what will the heat do that could be harmful
Woodonglass
Uhhmmm, destroy the gelcoat on the outside of the hull for starters!!!:eek: I mean it REALLY gets HOT!!!!
jbcurt00
What are you going to do w/ the transom skin once you get done w/ put back? Gelcoat? Paint? Nothing?
The newly installed plywood transom is covering the inner surface of the proposed mount locations, correct?
If you have to do any repair work or touchups on the exterior transom, I'd consider cutting the one closest to the center of the boat off. Done in such a way that you could build a plywood wedge to install against the back of the transom plywood, after you wrap it w/ CSM & PB it in place. Then put the removed piece back on.
Status
