Deep cycle battery for stereo
mschwartz815
I learned a long time ago with my car.. Play radio too long with engine off, engine wont start. Started out with a full size deep cycle marine/rv battery. Was no problem on my Tahiti bubble deck. Plenty of room under bow for battery. I even rigged a cig lighter to the battery and wired a plug to charge the battery without
taking it out of the boat. But now I have a bowrider with no room for a full size lead acid deep cycle battery. Then I researched smaller deep cycle batteries, and found a sealed AGM wheelchair battery that fits anywhere, can be used at any angle and once I figured out a trickle charger was not adequate to keep it charged.
I am once again rocking on the water without the risk of draining the starting battery. Eventually I will add a battery disconnect switch to charge the audio system
battery whilst underway.. Pictures to follow...
gm280
Oh yes a stereo system connected to the starting battery is not a good idea. The radio will play, but the engine may not start. Good idea to use a dedicated battery for your stereo system.
moecarama
What size wheel chair AGM battery did you use, weight, dimensions, and ampere hours?
MH Hawker
i was wondering about the AH rating my self and you do realize that 12.2 volts is 50 % discharged and depending on the watt out put of the radio a 200 watt system will drain it fast
A low power standard car radio with 20 watts should last a lot longer
