Since i need to know where im starting to get to where I am going, I am in desperate need to know where i shouild set the Idle screw after a rebuild? the manual i have does not tell me where to set the idle screw.(I should of marked it). The engine is a 92-94 force 40hp 2 cylinder 2 stroke, I do not have a serial number. I set the Air'Fuel mix screw out the 1 1/8th turns but do not know where I should set the Idle screw. I figure I would ask, so i don't burn up my Starter trying to chase it down. Pretty much asking so I can get it tank started and make my final adjustments on the water.
