Re: defrance between 1;61 gear 1;89
sorry about the miss spell im not very good at spelling but boy can i build a great motor from scratch ok so if i have this right my motor is turning 1;89 rev for 1 turn of the prop i need less revolutions from my motor it will turn the prop faster lowering my overall rpm and putting more burden on my motor so 1:61 will do that
You are complicating this too much. It's very simple. All you need to do is put on a "bigger" prop with more pitch. I am guessing that a 21" or maybe a 23" would hold your rpm down. I can't be certain until I know how high the rpm will go now.
Since these props are available in 1" increments, it's easier to fine tune the selection(but you need to know where the starting point is).
Jam that throttle wide open for a short burst too see how much rpm it'll get, so we can then say; you need to add this much pitch.
The 5.7 motors of that year group usually ran a range of 4200-4600 rpm.
The higher gear reduction(1.89) is easier on the motor than the lower one.
Is this your boat?
