dingbat
- Joined
- Nov 20, 2001
- 17,318
I have a couple of places where the gelcoat has, or is, starting to delaminate on the hardtop. Most of the delamination has taken place around a couple of holes the PO filled with 5200 and water got under the gelcoat.
I drilled out the 5200 and cored the hole with wooden dowels and epoxy last year but now have the delamination to contend with. I also have a couple of places on the edge of the top where the gelcoat cracked and I'm guessing moisture got in there an froze lifting the gelcoat off the fiberglass.
It's obvious that I need to remove the damaged gelcoat and let the underlying material dry out before doing anything. Question is, how should I repair these areas? I?m a newbie to glass work so any insight would be of help.
