rabbitprobe
Thread starter- Joined
- Jul 17, 2010
- 9
I have a 1973 volvo aq170b that had a bad coil. It was tough only SOMETIMES to start with the bad coil and would die only when the coil got hot. Anyway, I replaced the coil and everything was a go. But it started to get tougher and tougher to start. It always would, but I'd have to crank the crap out of her to get going. Once going it ran like a champ (would sometimes die near idle though). Thought I had a timing and idle problem, but it was still there after adjusting both. Finally she just would not start. I pulled the ballast resistor off and sure enough it was bad (broken core). I didnt have my meter with me so I could not get any voltage specifics, but I could feel spark at the distributor (but much weaker than normal), even with the broken core of the resistor. I'm putting in a new resistor this week, but my question is do you think the bad resistor was the cause of the delayed starting? I've heard that these work or they don't, start or no start (or start and die if there is a 12v bypass, which mine does not have).
