Re: Delco est conversion
I thought the same the first time I looked at the timing charts and questioned if it's correct, less initial timing should yield less max timing,,, not more?!? That data is direct from the manual, but that doesn't mean there wasn't a typo or incorrect data. The only way to know for sure would be to check it out with an advance timing light, but I do have a feeling the a feeling the max timing would be less with less initial timing, opposite of what the manual shows.
Fishrdan, the total advance numbers don't make sense.
From the Volvo manual with the 3.0 and EST distributor, a 1? BTDC base timing would yield 10? @ 600RPM and 23? @ 4600RPM.
The advance curve listed in the Volvo manual lists advance all the way up to 4600RPM. I have seen other charts where the advance does stop at 2800 so not sure which one is correct.
