Boat is a 1989 Malibu Skier with the Mercruiser Comp Ski 5.7 engine, 700 hours. Rochester carb and a point distributor. After a head replacement due to overheating I lost 800 rpms, used to get 4400, now only 3600. Based on the bad advice of a mechanic ("you need 36 degrees of advance, you are getting only 24, that's your problem, you should replace that Prestolite distributor"), I purchased and installed a Delco EST distributor kit. Since found out that 24 degrees is correct.
I set the initial timing with the "initial timing harness" to 8 degrees BTDC at idle. When I remove the harness, the timing goes to 20 degrees at idle and the idle speed becomes erratic, and on a test run went from the spec 620 rpm to about 1000 rpm constant. Advance stays about 20 degrees all the way up to 3000 rpm at the dock.
Whats up with this? Any suggestions? Should I just tweak the carb throttle stop idle adjustment? I am afraid if I do that I will have starting problems.
Oh yea, at WOT, I still get 3600 rpms. Replaced the fuel filter. I suppose it could be a carb problem. I can't smell it, but some skiers say they can smell gas while skiing. Just smells rich to me, like cars before all the emissions control.
