DELCO EST.. The advancecurve goes up too fast. OMC cobra. 4,3L
aov004
Hello.
I just bought a new electronic ignition. Delco EST.
I wired it up and started the engine. Everything worked fine. I put in the jumpercable and adjusted the timeing till 6 deg. btdc as my manual says.
THen I took the jumper away and put in the black wire.
When I then use my strobe I can see that the ignition foes up to 20 deg. around 1500 rpm.
Anyone knows how too adjust the advance curve or is there a box or something I can get too make this work??
Thank U very much for all help and tips.
Lou C
Re: DELCO EST.. The advancecurve goes up too fast. OMC cobra. 4,3L
in my 88 OMC manual, the advance curve for the 4.3 shows centrifugal advance starting at 0* at 1000 rpm, about 6* at 1500, 8.5* at 2000, 10* at 2500, 12* at 3000 and 12* at 3200 which is full centrifugal advance. (for total advance add your 6* base timing to these values
As long as you have the right dist, you need to find out the right procedure for checking advance on it, I seem to recall having to disconnect something on those, I have ancient points so that's all the experience I have in marine systems....
Don S
Sounds like the module may be defective.
aov004
Thanks for your tips. Went back til the shop today and he changed the module.
I write back as soon as I have changed it!!
Hope for the best!
bwporter
I just purchased this kit for my 1989 Fours Winns 180 Horizon with a 4.3L V6 OMC Cobra stern drive with breaker points ignition system.
="http://www.michiganmotorz.com/delco-voyager-marine-electronic-distributor-p-121.html"
Did you figure out the problem?
Based on my research I should be able to swap out the old distributor, coil, wires and ESA module, install this kit and run the engine with no issues.
CobiaXL
Banned
Your link isn't working,here is the fixed link.
