Thanks. Now if I can just find actual replacement! All of the resto threads are 60-odd pages. My questions specific to the outboard involve the splash well, whether to remove or not, that kind of thing. And as materials change is marine ply still best? Coosa?Transom replacement is basically the same for any tin StarCraft ob
I have similar through-hull pitting on my Chief too. I sealed it up on the inside with JB MarineWeld and will be adding an aluminum patch (which is already made) on the outside. If I ever get back to work on the thing!HELP!! Is there a fix for this, or am I screwed? Have had the boat about a month and have been working at getting the trailer squared away. Got new springs, axles, tires installed and slid suspension back to dial in the tongue weight. Next is bunks. With the boat lifted off the bunks a little I noticed some pitting in the hull. I put the plug in and filled the hull with water, and sure enough it’s rotted through in a couple of spots What to do? Yes, it looks like the bunks are pressure treated![]()
I had a 14' Sea Nymph which had a hole and I patched it with JB Weld from the outside. It never leaked after the repair during the short time that I owned the boat. Not the best way, but it worked.So, is JB Marine the best solution to patch from the outside, or 5200, or is there some specialty product? I really wasn’t looking to gut the thing right now...
looks like chieftain 18 .....Back on the ground, everything retorqued under load. Moved the winch stand forward and scooted the boat up a few inches, managed to get at least a little tongue weight. More to come on that after I replace the winch and slide the suspension back a notch or two. Also need to replace and adjust the bunks. On that subject: found some pretty significant pitting where the aluminum has been resting on the bunks. I hope there’s a fix for that!
