Despertly Seeking Help With A 1986 85hp 3clydr Crys Outbrd
jsweetguy320
i have a 86 chysler 85 hp outboard that i need help with a person messed with the distributor cap said he just cleaned it i need to knowthe firing order which one is #1 also whr the number one setting on the cap is
4runneradam
Re: Despertly Seeking Help With A 1986 85hp 3clydr Crys Outbrd
Distributor cap? Everyone I've seen has the CDI box ignition setup, including mine.
Yours has a distributor? I thought those were on the older forces, from the 70's?
uhhh nevermind you said chrysler not force
sorry :) (couldnt figure out how to delete this post)
roscoe
Uh, first you need to id the motor model and year.
It is not a 1986 Chrysler, as they stopped production in early 1984.
Do you have the model number? similar to 856B2K ?
jsweetguy320
hello its a 857h9g model num 2235
roscoe
ok, according to the model number, you have a 1989 model.
But, it should not have a distributor cap.
And it should not say Chrysler on it anywhere.
Chrysler was forced out of business in 1984 when they went bankrupt.
1984 thru 1989 models were made by US Marine. Then in late 1989, Brunswick (Mercury) bought them.
So, You may have parts from several motors, put together.
Perhaps they put an old Chrysler cowl on the motor to replace a lost or broken one?
But that doesn't explain the distributor.
Don't know what else to tell you except to post some photos.
chitownborn
could it be a 1979 model they had distributers?
Frank Acampora
I think it was in late 1978 or early 1979 that Chrysler stopped producing distributor ignition and went to Prestolite distributorless. That was when they first made the one piece lower unit, but the initial engines still had distributors. If you have a 2 piece lower unit with a pin drive prop, then for sure the engine is not an 80s engine.
Regardless of what the model number says, if it has a distributor, the firing order is 1,2,3, just as on any 3 cylinder Chrysler or Force. The top cylinder is number 1. The wire closest to the block rearward (on the distributor cap) is #1. The distributor rotates clockwise, same as the flywheel, so the wire closest to the front is #2 and the wire closest to the hood is #3. The cap has a hole in the rim into which fits a boss on the dist. body so the cap can only go on one way. The dist. pulley has a circular groove with a straight line centered in it. With the #1 piston at top dead center, the straight line should point to the flywheel and the groove should match the curve of the flywheel. This sets the rotor at top dead center on #1 cylinder. Just look at where the rotor is pointing and you will now know #1.
You really don't know what you have: Since the manufacturers left the distributor mounting bosses and the CD box mounting bosses on ALL castings until Mercury discontinued the Force engine line, you may have an older block replacing a blown one OR you could even have a newer block retrofit to distributor ignition. It only takes tapping two 3/8 inch holes to retrofit. Even the old timing linkage tower will fit with no modifications.
People do strange things to these engines. I do know several people who think the distributor ignition is preferable to the Prestolite distributorless ignition.
So, old block, new block, retrofit because the Prestolite failed, or retrofit because the owner just wanted it. Could be anything or any reason.
