Flynny
- Joined
- Jul 22, 2011
- 86
We bought a 2004 Wellcraft Sportsman 180 in November that has a live-well and the pump is a Shureflo ProBlaster. The seller told us the live well pump was not working and those were part of the conditions; I figured it would probably be a simple fix.
The first thing I did was check the fuse, and sure enough it was a 10-amp (not the recommended time delay 15 amp) and it was blown. So I replaced it with a regular 15 amp fuse from Radioshack because I could not find a time delay 15 amp blade fuse anywhere. As soon as I flicked the switch, the fuse blew. I checked the fuse terminals and they were clean so I inspected the pump. It's dirty, but I can't see any corroded wires or anything like that. The guys at West Marine say the motor is most likely blown and I should just replace it, which is what the previous owner was planning on doing.
Before I scrape my knuckles off working through the tiny stern hatch near the O/B, is there anything else I should try? I did try a second 15 amp fuse and that one blew as well after a few seconds. I just thought of this, if the pump was jammed, would that cause the fuse to blow quickly like that?
