bostonwhalermontauk1965
- Joined
- Sep 4, 2010
- 91
Hi guys
I know this question seems as if I stayed up late at night to dream up a silly question to throw at you - but here is my issue....
I just spent a lot of time restoring my late fathers 1965 Boston Whaler.I have to replace the bow light. I am trying to retain the original look as best I can. However , the bow light - which I have found an exact replacement - is very small. I really want to stick with the factory look but I found a similar one as a replacement known to be seen for 2 nautical miles. The direct Boston whaler replacement manufacturer cant tell me how far that one can be seen - but tells me it is up to OEM specs - which lets face it - back in 1965 wasnt too high. What are everyones thoughts on going with the aftermarket similar one for the known two miles - or what are the factors which make a light seen from further away? - Is it a larger lens, or more bulbs in fixture or what? - Also and thank you again in advance - For the same boat - what hight does my stern light have to be for it to be up to USCG standards? I have to put a new one on and want that to be correct and safe as well - I plan on installing one that can be seen for 3 nautical miles (Stern Light) Lets hope if it is just a matter of more bulbs to increase visibility - then two naut. miles on bowlight and three NM on sternlight with the motor off too long dosent run battery down too quick.
- Thank you all again - Paul
