Determining spark plug gap
gsonnier
I have a 93 25HP Merc. Trying to determine the measurements for gapping spark plugs. I finally broke down and bought a Seloc manual for my 1993 25 Mercury. I see a chart for "Piston to cylinder clearance" and "Piston Ring End Gap", but no dimensions for 6-25 HP's are given. It just says "N/A".<br /><br />Where else can I find this or does it matter that I gap them? Thanks.
wilde1j
Re: Determining spark plug gap
Do you have the motor torn down? If you don't, why do you care about ring gap or piston clearance?
rickdb1boat
Look in the front of the book. Should be under "Engine Specifications" or "Tune-up Specs". But in case you can't find it: NGK Plug # BP8H-N-10 Gap.040 (The Gap will be the same, no matter what brand of Plug you use)
gsonnier
Thanks for the info and direction Rickdb. I must have read right past the most important part.
HowieDean
Also keep in mind that the recomended gap is in the plug number BP8-N-10 ,, that 10 is 1.0 mm or .040 inch... If you want to know what all the letters and numbers in the plug number mean click here... NKG sparkplug info
gsonnier
Do the plugs come out of the package already gapped? In the past I usually drop my rig off twice a year for tune up. A couple of times I ignorantly replaced the plugs myself with new ones right out of the package. From what I've heard, I can burn up an engine without the proper gap. I guess I just got lucky?
rickdb1boat
You need to Gap them, as you never know what the factory has them at.
