I have a 1976 18' Starcraft Chieftain with an 84 Evinrude 150, 19" prop, T&T, no jackplate, has doelfin. Plate is even with the bottom of the hull. OEM says 4500-5500 rec. op. range.<br />I rescently discovered that my throttle was binding and butterflies were not opening fully. Repaired that. My max rpm was about 4900-5100 before this repair. Now I can achieve about 5400. In theory, a 21" or 23" prop should bring it into what I thought was a good range at WOT.<br />From what I understand, I should adjust the x factor first to achieve about 5800. I believe this means basically the vertical height on the transom. Increasing the x factor should increase rpms then bring in back down with prop????<br />How do I know how high I can go? <br />How can I do this without a jackplate? Hit or miss?<br />I know I can shim the motor but how high? <br />My boat does squat fairly far when not moving. Light boat with heavy motor. No it is not overpowered.<br />Thoughts??<br />
