Do it in the fall !
Do it in the fall !
Definetely would not hurt but not the most effective time. Spring is when the growth starts and aeration will have it's best effect during that time. Aerating in the fall will let the holes close up and not allow the nutrients and oxygen down below at the time they are most needed.
I beg to differ ... dethatching in the spring is stressfull on your lawn as it will destroy a good percentage of the new growth shoots that start in the spring. In the fall is the best time to both aeriate and dethatch. When you have warm days and cool nights, the roots are developing. It wont grow that fast on top. Bit it will on the bottom [roots.]. In the fall its best to use a low nitrogen, high potash fert. the 1st number ixn the fert mix is nitrogen] thats what gives the grass its green and makes the grass grow on top The second num is phosphores, and the third number is potash, which is for root development. The basis for any healthy lawn is a good root system. High nitrogen ferts are like junk food, speed. Like 25-5-5 thats junk food,. Causes it to grow too fast, end up with thatch problems..thatch brings insect problems and the grass roots actually gro into the mat of thatch instead of the dirt. Golf coutrses aeriate 3 of more times a year, but the best time for any of that is in the fall. Seeding as well. If your going to do one thing aeraite inthe fall and put down a low nitro high potash fert and reep the benis next spring
There's a tremendous difference in weather in the "northern half". Around here, to wait till early summer would be killing the lawn since that's the beginning of the dry season. If you're where there is abundant rainfall, no sense in not dethatching and reseeding early. That way you get to enjoy a developing lawn most of the summer. You can allways overseed in the fall if it's needed. And if you're looking at getting rid of the nuisance grasses, it's probably a little late. I applied Round Up about 4 weeks ago to those areas so it's now just about the right time to replant those areas.
Well in my neck of the woods, the PNW, I would create a sodden quagemire if I dethatched in the fall. So mid spring it will be.
The one thing that hasn't been mentioned is that aerating, topdressing, fertilising with the appropriate fertiliser for the time of year....are pretty much ALWAYS a plus.
Thatch does not always build to the point of being a problem, and beyond any discussion in here about the pros and cons of timing...the most important element is simply to confirm whether there is even a need to dethatch.
Sort of "if it ain't broke, don't fix it".![]()
....the most important element is simply to confirm whether there is even a need to dethatch.
