First sorry for being so long winded. I recently purchased a 84 Merc 75HP. It worked great the first couple of times I took it out, but it was idling very fast. I adjusted the throttle with the pickup screw. It was nice and smooth. Next time I took it out, it wouldn't start, I turned up the idle and it started. Used it all day. Next time out, used an older metal gas tank which had a little rust in it. It ran great for the first few miles then the primer bulb went soft, I checked the vent and it was open. I took the gas line and plug it into my plastic tank and worked fine again. I decided to decarb using some seafoam. I took it out once again and it would go good at idle, but once I kicked the throttle up, it would just die. Starts with no problems, but would die intermittently when I would throttle it up. If I'm lucky, I can slowly throttle it up and it will plane out. But still not the same speed I was getting when I first ran the boat. Also while on the water I monkeyed around with the Spark Stop Screw. I have changed the fuel line, bulb, took off the new inline fuel filter (thought maybe it was not allow enough fuel to go through it), cleaned out the fuel filter screen that is built into the motor. I also checked the plugs,and it was fouled with some aluminum on it on clynder 1. Didn't think nothing of it, decided to use some deep creep on the carbs. Took it out to test, and still the same problems. I have pulled the plugs once again and aluminum on clynders 2 and 3. <br /><br />What are the possible causes of detonation?<br /><br />Prior to all these troubles my cold engine compression was at 135, 109, 125, the 4th clynder I could not get to measure it<br /><br />Any help would be appreciated!!!!
