DF 100a stalling as soon as its in gear.
Wurzle
Hi I don't seem to be able to find anything on this subject. My suzuki DF 100a stalls as soon as you put it into gear. 3 beeps.
What I have done so far is try to adjust the cables to keep the RPM up to no avail. I have cleaned the AIC. I have disconnected the map sensor. I have had it on my PC to see if any of the switches are not working. The aic is working fine. The neutral switch works. Infact all the switches work when they should. I have disconnected the map sensor and the RPM goes up to 1500 on tick over it no longer stalls but its still not usable. The telefex cables are correctly set up.
Has anyone any idea where I should look next please.
My guess is I need to replace the map sensor.
