Short version, i have removed all of the bolts under the valve cover, and the two nuts under the head.
It will not move. Is there something hidden in the pan or engine mount? My manual is aftermarket and does not show any other hardware.
A little help please!
Long version.
I picked this motor up about a year ago for $750. It ran at the time.
It had been used on some research vessel.
The first problem turned out to be sea water in the fuel system.
The 2nd issue was water in the oil. I cleaned out the fuel system, replaced a few parts.
I changed the oil and hoped for the best. The motor was for a 17' whaler that need a lot of work.
I have put a lot of work into the boat and we have come full circle. The motor has been on the water twice, it runs good, and idles great.
There is a hesitation coming off idle, the the throttle is stiff as is the steering. The problem is there is water getting into the oil.
I have started pulling the beast apart hoping for a leaky head gasket.
The head will not come off, what am I missing?
KP
Long version.
KP
