Michawilden
Thread starter- Joined
- Apr 4, 2015
- 153
Hi All,
DF9.9 electric 2015, carb version remote control
I got an outboard from a friend. It has sunk, they took it out of the water and gave it to me( after a week).
Got the water out and got it running properly. changed the oil a few times. It ran well for a couple of hours. I let it run multiple times for an hour to get all the water our but oil is still milky.
Now the last time it would not stay running. I start it, it runs well on two cilinders for 5 or 10 seconds and than the lowest cylinder cuts out. It shakes and it dies. When I start it up immediately, same thing happens. runs on two cylinders and lowest cylinder cuts out.
Lowest spark plug is moist ( fuel). It does spark however. When I pull the plug when it is running on the top cylinder, big arcs jump to the powerhead/ metal. But it does not change how the motor runs.
Did a compression test, both on 145 psi.
Since the oil stay milky, I suspect that the lower cilinder gets water inside and therefore quits. It takes the water like 5 seconds to reach the powerhead. But I ran it outside the bin with the lower unit in the air and the same thing happens.
I do not get an overheat/ low oil pressure light. I cleaned the carb a couple of times now. Changed out the ignition coil with another, no change. swapped the spark plugs and the problem stays in the lower cilinder. Now I ordered new sparkplugs to test those.
Else I am stumped. Anybode else might know what could be the cause of the lower cilinder dropping out?
