Hi Sir,<br /> <br /> I have the motor I rebuilt broken in , finally.<br /> <br /> It is set up , with anti- ventilation plate, approx. 2 " above bottom of hull. Second hole from top.<br /><br /> I have run a aluminum ( stock I think) 13 X 19 . I get 5200 rpms , with , best I can figure average load.<br /><br /> I also had tried a 12 3/4 X 21, SS , all I know is its a michigan wheel prop.<br /><br /> I only had 4800 rpms with it.<br /><br /> The boat is a 15' 6" Procraft, bass boat. Motor is a 78ETL115.<br /><br /> Other then the rpms , the motor does great on boat.<br /><br /> It gets out of the hole great with either prop. It will run on plane ,down to about 20 mph. <br /><br /> There is little more then the prop and pad in water, when trimmed up.<br /><br /> Handles perfectly, in turns.<br /><br /> I didn't notice much difference in WOT speed between the two props. Right around 45 mph , GPS.<br /><br /> What do I need to do to get my rpms up ???<br /><br /> Do I need to drop down to a 17 P prop ??<br /> If this is what you recommend. <br /><br /> Can I get by with an aluminum prop ???<br /><br /> I dont have the extra cash ,for a $200.00 + SS prop , right now .<br /><br /> I'd be glad to trade someone the 21 SS for a used 17 SS . If this is what I need.<br /><br /> Thank - You,<br /> <br /> KYhunter
