GrindKore
Thread starter- Joined
- Jun 20, 2008
- 211
Today I decided to finally install the tach. I tested the terminals RED(+), BLACK(GND) under the dash and they were putting out 12V DC as they should when ignition key was on, next I located the purple wire terminal and connected the signal wire to tach.
Once I have connected everything to my new tach and made sure there are no shorts (I used crimp-on terminals on my tach wires). I double checked all the wiring on the tach once more. When I turned on the key, nothing happened. I hooked up the muffs and proceeded to turn on the engine, it won't start, power trim does not work, choke solenoid does not work, the power on the terminals that I have measured is not there. I verified all battery cables are connected correctly and are getting 12V on the rectifier terminals in the motor. The circuit breaker in motor did not pop, also now when I measure the resistance between GRND and RED wire on the terminal below dash, it is 0 Oms. I took apart my Commander 2000 remote and inspected all the wires, I do not see any signs of shot circuit, melting or overheated insulation.
I'm looking at the wiring diagram and do not see any in-line fuses, any ideas as to what can be causing this? This boat was running like a champ before I went to install this tach today, now electrical if FUBARed.
