Did I get a good deal?
Michigan Jason
I just had to get a new prop shaft and 2 bearings and a few seals all new in my volvo penta sx 1995 outdrive. I was told that volvo parts are more expensive than others and this job at a marina would have cost me $2,500-$2,800. My uncle is a marine tech and he did most of the work and sent the outdrive to a volvo tech he trusts for the rest. I payed $1,100 at the end of the day for parts and labor. Did I get a good deal?
A little backround, (my old prop shaft had so much runout that it was impossible to straighten it, and there were no used prop shafts available. There was a vibration while accelerating and I was told it was caused by the major runout and the couple of bad bearings. My gimble bearing was good and so were all the u joiunts, and I had no water in the outdrive.
Michigan Jason
Re: Did I get a good deal?
No one? Nothing? Lol... Cmon you guys, someone knows of pricing on this kind of stuff..
bruceb58
Its a good deal if you think it is...not sure what you want to hear. We have no idea of the quality of the work. You know better than we do.
sethjon
Sounds hi if you got a deal from an uncle. A total overhaul should cost around $2500 so you be the judge. Were the gears in good shape?
Michigan Jason
Well, my uncle doesnt do volvo, hes OMV, MERCRUSER... He has a good friend he has dealt with for years and he does volvos, so he sent the outdrive to him. My uncle is not charging for taking the outdrive off and putting it back on, I am paying the other guy for parts and labor. I guess the guy is making some money on the prop shaft, and about $400 in labor. $1,100 is what I payed at the end of the day. I will have a brand new prop shaft, new bearings in the outdrive and new seals.
Michigan Jason
I am assuming the gears were because the volvo tech didnt say they needed work..
