Britcheflee
Thread starter- Joined
- Oct 4, 2010
- 79
So does the following information taken from another site be followed for the fleetwin I have? Just put in 1 pint of 30 wt oil in the gas - should I have used the marine two stroke oil instead?
Oil - Oil Mix
Never, ever, use automotive oils in your air-cooled outboard. Yes I know the instruction decal says "automotive SAE 30" however today's automotive oils have additives that make them completely unacceptable. You should use the original recommended fuel mix ratio of 1/2pt of oil per gallon of gas but with modern TC air cooled 2-stroke oil. On my motors, I use 3/4pint of air-cooled 2-stroke oil per gallon of regular gas for added security. I've had very good luck with the Sthil brand of 2-stroke oil and Golden Spectro 2-stroke - this is the same stuff I use in my mopeds and yard equipment. People always ask me "do I really need to use so much oil" and the answer is always the same - YES!! Oil is still cheaper than parts or a new outboard: USE THE CORRECT 16:1 ratio and the correct type of oil - period!
It says for air cooled engines but concerned I used the wrong oil in the 7.5 fleetwin which says exactly that under the cowl.
Lee
Oil - Oil Mix
Lee
