500dollar744ti
Thread starter- Joined
- Jul 23, 2012
- 691
1990 Merc 350 Magnum and this is my first I/O winterization.
-hull drain already out
-removed drive and changed the gear oil
-stuffed an old towel in the drive bellows to keep debris out
-covered trim rams in plastic and supported them so they aren't sitting on the ground
-removed what looks like the riser drains, poked through the gunk and not much of anything came out
-removed hoses to manifolds, lots of water drained out
-removed power steering cooler hose, got a good amount of water from that
-removed big hose on circulating pump, got a lot of water out of that
-removed both drain cocks from engine block, poked both drains clear and got a ton of water out of each side
-turned steering ram so it isn't exposed and coated the motor over with some silicon spray to keep away corrosion
-put the cover on the boat
