Did Wallyworld change their supplier or did I get defective TCW oil?
I opened a new gallon of SuperTech TC-WIII oil today. I had used the stuff for years and expected to see the usual royal blue oil color. What came out was medium green and seemed thinner than the usual. I put some of the green and the blue into identical containers to see if I could detect any difference.
After shaking and looking, it appears the blue stuff has more body, but admittedly my test method is not real scientific. Anyone have any ideas? Anyone ever hear of defective oil?
JB
Re: Did Wallyworld change their supplier or did I get defective TCW oil?
Good grief!! So green oil is supposed to be not as good as blue oil?? If Shell made it it is good oil.
DC20
You could do a viscosity test.
I'm not an artist but isn't blue and green in the same color family? Maybe they just changed the dye or amount?
Just a thought.
woody66912
Be careful, mixing oils can result in them building sludge up in the bottom of the oil tank.
Frank Acampora
The oil is dyed simply so you know it is added to the gasoline. Color makes no difference.
Run your engine with the green oil and if it seizes then sue Wal-Mart. LOL
catfishcarl99
ya there always switching things around. they just did a change over from seasense to shoreline marine here at all of them with boating supplies. the green should work fine. prob was cheaper dye lol.
Folks, thanks for the responses. I realize that one color of oil dye is just as good as the other. That is not the issue. I like green. I was hoping someone knew if Wallyworld had changed suppliers.
Has anyone ever had a batch of defective oil? I have never seen that, but was curious.
Sea Rider
Used Chevron 2t TCW-3 blue dyed for years which was viscose while pouring, switched to Amalie, which has less viscosity and it's green like the Incredible Hulk, both performs excellent, dye and viscosity will not give tech issues or better, worse performance. Just check to buy TCW-3 rated.
Happy Boating
robert graham
Someone at Walmart Purchasing in Bentonville, Arkansas could tell you if they've changed suppliers or just formulas/dyes.....probably have to do some digging around to find that out!....better to just go fishing!;) Good Luck!
royal0014
Master Chief Petty Officer
Blue oil, green oil, yellow gas.......
